Been having a lot of issues with my 2 stage Toro snowblower this year. The discharge chute seems to plug much more often than I remember. I tried Liquid Wrench garage door lubricant (silicone), but that seemed to make it worse. Today I used Liquid Wrench Penetrating Oil, and viola. That worked great! It was like having a larger engine. It is a 8 C.I.D. engine.There is no H.P. rating on it. I hope this helps some other warriors.
My Toro is the biggest piece of junk ODPE I have ever bought. I was drawn in by the fancy Chute joystick.
First season I had more clogs with the "anti-clog" system than I ever had with My cheap Yardmachines MTD in 25 years.
Next season, I did wipe on
ArmorAll very liberally all over the plastic bits of the ACS and chute. That seemed to hep a lot.
Also adjusting the valves after 20 hours allowed the engine run
much smoother and more powerfully.
They were WAY out of spec ( read:
tight ) on the Lonchin China engine.
The drive and auger control lever are too short and hard to hold engaged when running. Poorly designed.
The unit is very heavy but overly weight biased onto the rear wheels so it want to ride over the snow, even wit the skids set so teh scraper gap is minimal. But I paid $1370 for it I will deal with it. Note: it has a non-reusable 'cardboard' rocker cover gasket. Cheap,
ps: I forgot the drive speed 'gear' selector seized. Taking the bottom cover off, I found the factory never lubed the hexagonal cross shaft it rides on. Rusted solid. I fixed it myself since my servicing dealer are a bunch of schmoes.
At least it starts easy - with one light pull - and appears to be fuel efficient compared to the 8hp Tecumseh Snow-king
-Ken
