Maintainng Odyssey Extreme Battery
I have a couple Odyssey Extreme Group 65 batteries in my truck. They are a few months old. I would like to "permanently" install a maintainer in the truck and have the option of plugging it in when the truck won't be run for more than a few days and sometimes weeks (which happens often). I don't plan on using the "maintainer" to charge any batteries from a deep discharge.
Per Odyssey The recommended float voltage for ODYSSEY AGM2 batteries is 13.6 volts for a 12-volt battery at 77°F (25°C). They also say Regardless of temperature, the minimum charge voltage is 13.2 volts as lower voltages will damage the battery grids and shorten life.
Odyssey recommends the Battery Minder 2012 AGM. After some reading on here, I know @f355spider likes this charger. I have also read about the Battery Minder 2012. I recall a posting (I think) from @f355spider spoke to Battery Minder and they mentioned that they lowered the float voltage. I was not entirely clear if that was on the 2012 or also on the 2012 AGM? What is the typical/minimum float voltage of the 2012 AGM? Does the 2012 AG supply constant float voltage or some kind of "smart" operation when the battery is fully charged?
I recently purchased (still within Amazon return window) a Noco Genius GEN5X1. I have it hooked up and after some VERY limited testing, it seems the float voltage varies from 13.2v to 13.3v. in about 60 to 65 degree temps (no other temperature range tests done). Also, I am not clear on whether the Noco shuts off every so often and is not charging and that is the "smart" function. And if so is that bad for the Odyssey?
I sent a couple messages to Odyssey Technical asking about the Noco and received no response. I then sent a message to Odyssey sales and got a response the Noco GEN5X1 is fine. I asked if they have verified the float voltages and she responded no. So of course, my follow up was then how can you say it is fine. Her response, that is what I use at home in my garage! I would have to do more testing to see if the voltage ever drops below 13.2v.
Another option I was looking at is the Victron IP67 charger. I like Victron products and use them in my camper. With the Victron I can select whatever float voltage I want. I am not sure of their algorithm, etc and whether it is temperature compensated. I think @04GTO likes this charger.
Whichever one I select, I want to mount it in the truck. Ideally under the hood somewhere, though real estate is at a premium. I may have to mount it in the cab somewhere, but first choice will be under the hood.
The Noco wins out for permanent mount. It is designed for under hood mounting and is the smallest form factor. The Victron is IP67, so that should be good as well, though it much larger. I am not sure about the Battery Minder 2012 AGM mounting under the hood. I don't anticipate a wet environment.
Another question, can these chargers be attached to a car battery and plugged in when the car is started? I ask for the occasion where I remote start the truck from inside the house and have yet to unplug.
Thanks in advance for sharing your wisdom.
Update. I checked the noco this morning. It was floating at 13.07 volts in about 60 degrees.
Looks like the noco is going to be a no-go.
I own a NOCO, a CTEK and a victron.
NOCO. Solid plastic construction, lots of detail on the interior construction. Very conservative charge profile. Too conservative frankly. It’s the one I loan to friends. It really won’t rejuvenate a weak battery - it will half charge a drained one to get you started. Good 10A power supply mode,
CTEK. Gets hot when running. Is more intelligent than the NOCO with how it handles its voltages. Actually floats it whereas the NOCO seems to enter an on/off state. 4A is enough for most homeowner needs. Good unit. Permanently mounted but I mounted it over a plate of metal since it really shouldn’t have to get as warm as it does. YouTube tells me it’s not as well made. I really like it’s programming and it does have a gentle desulfation pulse which, when used long term, seems to make a difference… long term.
Victron. Built like a brick s- house. Solid metal case. Bluetooth gets you in to set modes or make your own. Also has a power supply mode. No front panel controls, none. It’s built to configure and walk away.
Victron for the win. If I ever need to buy something else for real, victron. If I need 1 amp to warm the mower, something cheap.
@99Superduty
I have an Extreme in my Harley. Battery installed in 2017 and always on a Battery Minder 1500 when parked. Zero issues even with cold -25f winter storage. Tests at 100%
