Maintainng Odyssey Extreme Battery
I have a couple Odyssey Extreme Group 65 batteries in my truck. They are a few months old. I would like to "permanently" install a maintainer in the truck and have the option of plugging it in when the truck won't be run for more than a few days and sometimes weeks (which happens often). I don't plan on using the "maintainer" to charge any batteries from a deep discharge.
Per Odyssey The recommended float voltage for ODYSSEY AGM2 batteries is 13.6 volts for a 12-volt battery at 77°F (25°C). They also say Regardless of temperature, the minimum charge voltage is 13.2 volts as lower voltages will damage the battery grids and shorten life.
Odyssey recommends the Battery Minder 2012 AGM. After some reading on here, I know @f355spider likes this charger. I have also read about the Battery Minder 2012. I recall a posting (I think) from @f355spider spoke to Battery Minder and they mentioned that they lowered the float voltage. I was not entirely clear if that was on the 2012 or also on the 2012 AGM? What is the typical/minimum float voltage of the 2012 AGM? Does the 2012 AG supply constant float voltage or some kind of "smart" operation when the battery is fully charged?
I recently purchased (still within Amazon return window) a Noco Genius GEN5X1. I have it hooked up and after some VERY limited testing, it seems the float voltage varies from 13.2v to 13.3v. in about 60 to 65 degree temps (no other temperature range tests done). Also, I am not clear on whether the Noco shuts off every so often and is not charging and that is the "smart" function. And if so is that bad for the Odyssey?
I sent a couple messages to Odyssey Technical asking about the Noco and received no response. I then sent a message to Odyssey sales and got a response the Noco GEN5X1 is fine. I asked if they have verified the float voltages and she responded no. So of course, my follow up was then how can you say it is fine. Her response, that is what I use at home in my garage! I would have to do more testing to see if the voltage ever drops below 13.2v.
Another option I was looking at is the Victron IP67 charger. I like Victron products and use them in my camper. With the Victron I can select whatever float voltage I want. I am not sure of their algorithm, etc and whether it is temperature compensated. I think @04GTO likes this charger.
Whichever one I select, I want to mount it in the truck. Ideally under the hood somewhere, though real estate is at a premium. I may have to mount it in the cab somewhere, but first choice will be under the hood.
The Noco wins out for permanent mount. It is designed for under hood mounting and is the smallest form factor. The Victron is IP67, so that should be good as well, though it much larger. I am not sure about the Battery Minder 2012 AGM mounting under the hood. I don't anticipate a wet environment.
Another question, can these chargers be attached to a car battery and plugged in when the car is started? I ask for the occasion where I remote start the truck from inside the house and have yet to unplug.
Thanks in advance for sharing your wisdom.
Update. I checked the noco this morning. It was floating at 13.07 volts in about 60 degrees.
Looks like the noco is going to be a no-go.
I own a NOCO, a CTEK and a victron.
NOCO. Solid plastic construction, lots of detail on the interior construction. Very conservative charge profile. Too conservative frankly. It’s the one I loan to friends. It really won’t rejuvenate a weak battery - it will half charge a drained one to get you started. Good 10A power supply mode,
CTEK. Gets hot when running. Is more intelligent than the NOCO with how it handles its voltages. Actually floats it whereas the NOCO seems to enter an on/off state. 4A is enough for most homeowner needs. Good unit. Permanently mounted but I mounted it over a plate of metal since it really shouldn’t have to get as warm as it does. YouTube tells me it’s not as well made. I really like it’s programming and it does have a gentle desulfation pulse which, when used long term, seems to make a difference… long term.
Victron. Built like a brick s- house. Solid metal case. Bluetooth gets you in to set modes or make your own. Also has a power supply mode. No front panel controls, none. It’s built to configure and walk away.
Victron for the win. If I ever need to buy something else for real, victron. If I need 1 amp to warm the mower, something cheap.
@99Superduty
I have an Extreme in my Harley. Battery installed in 2017 and always on a Battery Minder 1500 when parked. Zero issues even with cold -25f winter storage. Tests at 100%
I only tested the Battery Minder 2012AGM and it appeared to settle in around 13.4vt float at 77F/25C. When I asked Battery Minder tech support about this they said this was intentional, as they had complaints from customers of signs/symptoms of over charging during float. They claimed this change is across all models...but while I also own a couple of the 128CEC2, I have not tested them for this.
Note also that with the 2012AGM, it does temperature compensate, so I have seen the voltage go higher, even into the upper14vt range in cold temps in my garage...and it drops lower when my garage is in the 90s. The temperature compensation is automatic and continuous, so on my bluetooth monitor, I can see a smooth curve as the voltage increases overnight, as my garage cools and lowers during the day as it warms. It also has a continuous pulse desulfation during charge and float. It has been connected 24/7 on my "garage queen" Ferrari and inspite of using on a plate type AGM (H6/Group 48) from Interstate, has maintained that battery well for about 5 years and the battery tests as new. I just tested it two weeks ago. (Battery Minder recommends using their flooded setting on plate type AGMs and to only use their "AGM" maintainers or settings on Odyssey or other higher performance "pure lead" type AGM batteries)
I'm not a fan of battery tenders installed on a car...I did that once and it worked, but the battery was trunk mounted. For an engine compartment it is dealing with vibration, heat, dust and moisture. But the bigger concern is if the electronics go wonky, I see some potential for a fire. There are examples of these failing on some car forums. I saw one post of a guy that had his sitting on the carpet on the passenger side and it fried and burned up the carpet (Battery Tender brand). Fortunately the car did not catch on fire. All brands have this possibility.
Most of my battery tenders are wall mounted. If you wish for yours to be portable, just install the ring mounts that go on the battery terminals and carry the tender in the passenger compartment along with an extension cord.
Here is Odyssey's current approved list of chargers/maintainers:
https://www.odysseybattery.com/charger-comparison-tool/
I know these batteries are pricey but I think they are less picky than you’d expect.
I got a used Odyssey Extreme many years ago for $20. Used it to start various vehicles, it spent some time in storage, then I soldered some cheap jumper cables onto a cheap consumer grade UPS/battery backup to extend its runtime. Worked for probably 5 years that way. I’m sure whatever charging profile that thing had (designed for a small sealed lead acid battery) was not ideal.
Eventually I tossed it in the garage when the UPS died.
Then I took it to work, express charged it, tested it, and sold it to an acquaintance for $20.
It still works fine to this day. Yes it’s like 10 years old and has been mistreated that entire time.
Just enjoy your battery and use whatever maintainer you have :)
Come to think of it, I had an Odyssey I purchased years ago from Sears. It was the Sear Platinum AGM but private labeled at the time from Odyssey. I had it in a Ferrari I had for about four years (until I sold the car) and it was great. It was a 34R size and I used a NAPA 1.5 amp on board battery tender on it. No issues for those four years...it was plugged in probably 50% of the time in my garage.
How long does the vehicle sit for? Odyssey (also X2, both made by Enersys and are identical specs for the same size) batteries are quite robust and not particularly picky about charging profiles in my experience. Heck, the X2 in my previous Tacoma was around 8 years old when I traded it in. That battery had seen 4-5 discharges below 9v while I was deployed and it was parked outside in temps form -20F to 100F+, no garage space. I just simply hooked it up to my Viking (Harbor Freight) charger in recondition mode and let it do it's thing no matter the outside temp. The battery was still functioning great when I traded it in.
On my Motorcycle AGM (Yuasa) I have a simple Battery Tender and it's held up great. My MR2 has an Interstate AGM battery using a Schumacher 4a maintainer that's held up well for about 4 years, that car only sees about 3k miles per year.
I have been monitoring the 2012 AGM. It has settled at 13.21 in float. I wonder if Odyssey's spec of 13.6 for float is no longer critical and they have not updated their literature, or they are unaware that Battery Minder has changed the specs of that maintainer (and Odyssey still lists it as an approved charger/maintainer).
Does anyone have an Odyssey branded maintainer? I am curious what voltage that floats at.
I do. I have the 15 amp but I don't have any devices connected to tell me what it is floating at.
Remember it is also temperature dependent. When I saw 13.4vt, this was at the specified 77F. It will be lower voltage as the ambient temperature rises. It will go higher as temperature lowers.
As dogememe mentioned, it probably doesn't matter all that much, as long as you are close. I had a plain jane NAPA tender on my Odyssey for almost four years without issue, until I sold the car.
We shall see spider. I just ordered an odyssey H6 for the wife’s new car. FWIW, I’ve been using the 2012 agm for over a year on our 24 Altima which has what appears to be a clarios/nissan branded agm and no adverse effects. I did unlplug the temp sensor which taps it down a bit. I just tested this 12/24 agm before I took off for a 2 week, 2000 mile business trip and it tested way above its CCAs and still 100% SOH on my ancel.
An Odyssey group 48/H6 may be in my future as well.
BTW, if you order one, get it from FCP Euro...they offer a lifetime warranty. Only trouble is if it fails, you have to send it back. Your order the replacement first, then you get a store credit when you return the bad one. They do this for almost all the parts they sell. But if you don't drive a european car, you may struggle to find stuff to buy. :) They do sell a lot of car accessories and detailing supplies...and oil and filters...and yes, you can return the oil and filters for store credit too. https://www.fcpeuro.com/page/lifetime-guarantee
Their price is full list, but includes free shipping:
https://www.fcpeuro.com/products/automotive-battery-group-48-odyssey-48-720
Appreciate the tip. I ordered through autoplicity who more than likely just has it shipped from Odyssey. $283.54 with tax and free shipping. My only concern with FCP would be how much it would cost to ship it back. I sent my son a tiny box with a few things from Ohio To San Diego and it cost $27 and it weighed 1lb. A battery would probably cost over $100 at least. Still a good deal in 6 yrs if it failed.
I ordered mine through Napa with the 20% off. One was an in store pick up and the other was shipping to my house.
Pirateship.com is what is used by the guys in the "free FCP Euro oil change" thread. Basically you can receive commerical rates through them, or very close to.
I'll remember that for when the Altima Nissan battery craps out. I chose free standard shipping and they actually overnighted it from California. It'll be delivered today by noon, pretty impressive. Unfortunately I wont be home from eastern PA till next thursday and need to hop a flight to Phoenix on Sunday. The wife's going to be with me on this work trip so I'm going to leave the current battery in the car and on the 2012 for a week and hook the odyssey up to my 2012 AGM for a week as well. I'm on a mission to try and bring back this newish oem back from its current state and will maybe start a thread on its progress using pulsetech and BM. Unfortunately, I can't let the wife travel all over the Midwest with this battery as is, especially in an application that has a reputation for destroying batteries
