gathermewool
Site Donor 2023
I‘ve had and used my NOCO for the past year and a half, along with a second charger, a CTEK (56-158) 3300. I prefer the CTEK although it gets pretty darned warm just sitting there plugged in, not connected to the battery and very warm while charging.
My NOCO doesn’t maintain a high enough float voltage, IMO. After being hooked up overnight to the Forester’s battery the green light was pulsing this morning and voltage read 12.58VDC. I inquired with NOCO, who got back to me the same day, and this is what their response was:
Thoughts?
Our chargers do not use a traditional float voltage. Instead they remove the charge once it is complete and go into a low energy maintenance mode where they monitor the battery. If the battery voltage drops below its resting voltage (approximately 12.8V +/-0.2V) the charger will top the battery back off to full. This is a better maintenance charge for the battery than a constant float voltage.
Please let us know if you have any additional questions.
Regards,
Chris G
NOCO Support Specialist
Thoughts?
