Is there anything really special to a replacment "snow" engine vs. a standard engine? I see the little differences listed (big starter handle, primer bulb, snow resistant recoil assembly, etc), but anything major that you really need the "snow" engine, like a different carb?
I got an old two-stage blower for free that didn't run. It has a Tecumseh H60 that I got running for a few minutes (simple ignition problem) then it made a nasty clunk/bang and now it no longer has compression. My guess is the connecting rod broke which I have read is common with the H60. The body/controls/auger of the blower are good, minus a little surface rust. I figure that might as well be saved.
Anyways, I'm looking at the Northern Tool catalog and an 11.5 ft-lb. Briggs Snow Series MAX engine is $455. An 11.5 ft-lb. Brigggs 1150 series is only $289.99. Any reason a "standard" engine can't be used succesfully on a snowblower in the cold. Would it start OK in the cold without the primer bulb? I don't see one on the Briggs 1150 series.
* Assuming it bolts-up properly and has the right shaft size, of course *
Thanks!
Thanks!
