Heading to WA to visit family for the holidays and learned that snow chains can be mandated in certain areas we’ll be in.
I looked into this a bit and found the State statute here. There’s the following exception listed for AWD vehicles, “(a) Exception for all wheel drive vehicles. When "chains required" signs are posted, all-wheel drive vehicles will be exempt from the chain requirement when all wheels are in gear and are equipped with approved traction devices as specified in WAC 204-24-040 provided that tire chains for at least one set of drive tires are carried in the vehicle.”
If I’m understanding this correctly, the chains don’t need to be installed but merely need to be in the vehicle. Is that accurate?
I then looked into what’s considered an approved traction device, located here. And it looks as though tires without chains can be considered an approved traction device if they meet the following,
“(3) Approved traction tires. An approved traction tire must have the following tread characteristics:
(a) A minimum of 4/32 inch tread, measured in the center portion of the tire at three locations equally spaced around the circumference of the tire.
(b) A relatively aggressive tread pattern designed primarily to provide additional starting, stopping, and driving traction on snow or ice. The tread must have ribs, lugs, blocks or buttons the edges of which are at an angle greater than thirty degrees to the tire circumferential centerline.
(c) On at least one side of the tread design, the shoulder lugs protrude at least 1/2-inch in a direction generally perpendicular to the direction of travel.
(d) Tires manufactured to meet these specifications must:
(i) Be permanently labeled on at least one sidewall with the words "mud and snow" or any contraction using the letters "M" and "S" (e.g. MS, M/S, M-S, M & S, etc.); or
(ii) Be permanently labeled on at least one side wall with the mountain/snowflake symbol.”
It seems like the most important take away here is that tires with the 3PMSF stamp is what’s required. Do I understand this correctly? So if a tire isn’t a snow tire, then yes they do in fact require chains to be installed?
