There are small engines out there with pressurized oil systems. I took apart a 12-horse Kohler years ago that, instead of an oil pump, had a check valve and little plunger driven by an eccentric on the crankshaft. That plunger pumped oil through the filter and into the oil galleys. There are briggs & stratton engines out there- even really small ones- with oil filters, and I assume that they must have a pressurized lube system similar to that Kohler.
