I have 375,000 miles on my small block chevy, at 330,000 miles I had the rear main seal replaced.
I have read that there is a rear camshaft plug above the rear main seal on small block chevy's and that they may leak, I have a feeling that since I cleaned up this motor so good, that there was probably some crud around this camshaft plug and now that it has been cleaned up I have more of a leak on the back of my oil pan, it used to be just wet, now I have oil all over my drip tray.
I know the old saying, if you clean the inside of your engine you will have leaks, this oil that has leaked out is clean looking, does the transmission have to be dropped to get to this camshaft plug.
Are there any other plugs in the back of the block that I need to look at, all of the oil pan bolts are tight, maybe I need to get the car on the lift and also make sure my valve cover gaskets are not leaking.
