My Small Block Chevy with 360,000 miles has a slight rear main seal, I think, here is the story, when I replaced my oil pan and oil pump at 333,000 miles I put on a new rear main seal. I did the Auto-Rx thing at 343,000 miles and when I was done went back to 100% synthetic, it started leaking so I did another Auto-Rx clean phase to get the synthetic out, now I am on the rinse phase, I had oil on the trans pan and inside the dust cover for the torque converter, just some wetness, also some wetness on the back of the oil pan. I read that on a small block chevy if the rear main bearing is worn you will always have a leak, can I replace the rear main bearing and will this help. I am wondering if after the rinse phase is over this leak will stop. When I replaced the rear main seal my mechanic buddy said the rear main bearing looked fine. I am in no way blaming Auto-Rx for this leak as I have heard 2 piece rear main seals are finicky. If there is anyone with any knowledge please let me know, when this rinse phase is over it is Group III oil for me, with the 100% synthetic I could see it dripping out, the other strange thing is the leak seems to be on the back of the oil pan seal up high where it meets the transmission, maybe the leaking was because Auto-Rx was pushing out the synthetic oil, just a thought.
