You have to be careful about cardboard blocking the front, make sure it doesn't completely block all of the airflow.
Of course we don't know if the engine is really running cold, only that foresthawk says the gauge doesn't register heat. On a longer trip does it register cold?
What about the heater output? Many gauges are inaccurate or stick in cold weather.
Running cold does reduce fuel economy but it won't cause quick damage (like overheating could blow a head gasket). It would be preferable to pre-heat the engine or find out if the thermostat is working right.
