I have a 2014 Chevy traverse 3.6L with 208k original motor, chains, and phasers. I have always kept the oil clean and full. Car runs and drives perfect, no CEL or other running issues, idles smooth as butter, and plenty of power.
Around the 180k mileage mark I started to notice a 2 second clatter on startup, only if the car had not been started in 30mins or more.
My research pointed to a worn locking pin on the cam phaser, more research found multiple Toyota and ford owners had the same clatter and drove them that way for 50k+ miles with no issue. So I figured "leave it be just drive it"
Fast forward to current day cold start in Wisconsin with temperature at -5F. I got the normal clatter and well as the engine running rough and missing for 3 seconds after startup, after 3 seconds misfiring was gone and car runs perfect. It has done this twice now only when the temps are roughly below 0F.
I have a few (lots) of questions I cant seem to find the answer for:
1) What is the life expectancy of the cam phasers after the lock pin is worn?
2) If the phaser fails, what actually happens inside the phaser that causes failure?
3) If the cam phaser fails somehow will it leave me stranded?
4) Is the below 0F misfire related to the cam phasers (and actuators) taking a long time to "zero out" because of thick oil?
Appreciate any info!
This car has been so great to me and has logged 15K+ miles pulling a 5x8 trailer with dirt bike and gear, super reliable, comfortable to sleep in, never been stranded it just keeps going.
