My 17 Jeep Wrangler 3.6 has a normal 2" round gauge for temperature and runs straight up in the middle or within 1/16 of the middle at all times after it warms up. The other temperature gauge is digital and is located in the dash "information screen", this one, after warm up, is constantly fluctuating between about 200 and 226 but has gone as high as 232. It constantly goes back and forth between the two. Once it hits 200 it takes about 40 seconds to hit the high number of 226-230 then start dropping again to 200 then repeats. The radiator fan cycles higher and lower speeds but not in correlation with the temperature swings or even the AC mode. The engine does not overheat (boil over), but it does always smell "hot"
Is digital gauge oil temperature? Why the constant swings and never stabilizing even when highway cruising.
