Slippery Oil
An oil's "slipperiness" or frictional properties is only relevant as or if it pertains to wear and fuel efficiency. With so many different conditions existing in an engine, these properties are best measured on a finished oil in controlled running engines to get the full effect of the oil, rather than individual bench tests under specific conditions or of an oil components. Wear and fuel efficiency are effectively measured in the engine tests required for API certification.
I, to this day, hear mechanics say synthetic oil is "slipperier" than conventional. There are more otherwise great or decent mechanics out there than you would believe.
When I added Schaeffer Moly EP to my trucks oil that is the most slippery oil I have ever felt even when used. I think one of Shaeffers oil has the Moly EP already in the oil or its additives if you want a blended oil. Not sure but I would guess it is the Antimony in it.
I want to know how antimony makes oil more slippery.
Compare the friction level in a constant boundry lubrication senario between an oil with no AF/AW additives to one with a good dose of AF/AW additives. There will be a difference
Why should I believe a "great" mechanic? "Great" means what - they fixed your car?
You use a completely subjective term to describe a mechanic, and expect me to believe this source over someone like Tom who makes oil for a living?
I once heard an ASE-certified mechanic, who had over 30 years of experience, tell me that I couldn't use 0W30 in my Toyota 4 Runner. An exact quote "That oil is too thin on start, you won't have enough oil pressure until it warms up".
A great mechanic?
Is some oil more slippery than others that meet the same spec and have similar approvals? For example, would all API SP oils be equally as slippery? Is there an oil term that describes "slipperiness?"
the most slippery stuff
A great mechanic?
Well, a mechanic then, lol. They may or may not be handy with fixing cars in an expedient manner, lol.
Ever had an at least competent mechanic tell you that oil "Acts like a 5 on start-up and then warms up to a 30?" That one made me :mad:
It's not just mechanics. Engine builders, even well known ones, spread a lot of myths and misconceptions. I have to remind people that engine builders are not tribologists, especially at the mass production crate engine shops. Someone slaps parts together per a recipe, do a quick function check, and send it out the door. They couldn't tell you the ring tension or cylinder to wall clearance, much less the hone profile or anything related to lubrication regimes. The builders that do understand that stuff aren't building crate engines.
Have you ever felt Moly EP? I have felt several brands of oil over the years and additives-stp, lucas, various liqui moly, rislone, hot shot, super techs and more but nothing compares to how it feels. My assumption of the antimony being that cause is a educated guess as none of them have that much of the antimony additive in them as the Moly EP. Have felt zddp, moly, tungsten and blended ester anti friction additives and they do not even come close to it. When seperate or mixed in oil it is the slickest oil/additive I have ever felt.
Most mechanics don't know crap about oil, lots of wives tales. Along with synthetic oil is slipperier than conventional, I've heard synthetic flows better in cold temperatures (not true when comparing the same winter rating oil), synthetic oil will cause leaks in an engine that's used conventional, you can't switch between conventional and synthetic, and that's just the synthetic vs conventional oil myths. I know a master tech who says trans fluid shouldn't be changed over 100k miles, I regularly service transmissions near or at 100k and the customers are always satisfied with the improvement in shift quality.
I don’t going around feeling things.
I also don’t use additives.
The "Starts off as a 5 and warms up to a 30" one is one I hear parroted a lot.
Also.. that 0W-20 is "like water!" Really doesn't mean anything, that one.
Maybe you should try it.
Which one? Because oil chemistry is complicated and just randomly adding crap to it can actually make the formula overall worse. In fact, the odds are pretty low that you are objectively making anything better, given a properly balanced formula in the first place.
