Bananas are slippery too if you step on them.Is some oil more slippery than others that meet the same spec and have similar approvals? For example, would all API SP oils be equally as slippery? Is there an oil term that describes "slipperiness?"
When I added Schaeffer Moly EP to my trucks oil that is the most slippery oil I have ever felt even when used. I think one of Shaeffers oil has the Moly EP already in the oil or its additives if you want a blended oil. Not sure but I would guess it is the Antimony in it.
This is REALLY useful: but only IF you are trying to affect how much finger pressure is required to hold, or not hold, a screwdriver between fingertips. B-)I found a post awhile back on BITOG, a user BOBISTHEOILGUY said to put a bit of oil between your two fingers. Grip a screw driver at the end only using those two fingers. Now try using Schaeffer oil between your two fingers. The screw driver fell out of my fingers much easier just as BOBISTHEOILGUY mentioned.
Fresh oil is the most slippery. That's all I need to know.
This analysis was undertaken to investigate the friction and wear properties of some engine oils. Fresh and used samples of these oils were examined. An original test apparatus simulating piston-liner movement was used for the purpose of clarifying the effects of various parameters such as load, speed and oil type. Amontons' law was obeyed up to a certain limit for some fresh oils and to lower or greater limits for others. Furthermore, a pronounced drop in friction coefficient was observed with used oils. Wear experiments showed a decrease in wear with the increase of the duration distance (the distance over which the engine oil was used in the vehicle). The electromotive force activity of the oils was shown to affect the wear phenomenon of these oils.
There is surface friction when not in full hydrodynamic lubrication. When the asperities at the surfaces are rubbing on each other, AF/AW properties come into play and that can effect the friction level. There's a lot of boundry lubrication going on in an engine. I know that CeraTech reduces friction ... the Mustang guys use it in the Coyote to make the BBQ tick go away, which seems to be kicked off by the friction level between moving parts.Is the coefficient of friction even a “thing“ for any modern motor oil? I would think viscosity drag would be a much higher order effect than the difference between any of today’s motor oils.
"This test doesn't simulate engine operating conditions perfectly, but it will give us a lot of useful information."This is REALLY useful: but only IF you are trying to affect how much finger pressure is required to hold, or not hold, a screwdriver between fingertips. B-)
Yes, such as what to avoid getting on your fingers while working on a car so you don't keep dropping screwdrivers"This test doesn't simulate engine operating conditions perfectly, but it will give us a lot of useful information."
Or how much beating your skin is able to withstand from carcinogens in engine oils.Yes, such as what to avoid getting on your fingers while working on a car so you don't keep dropping screwdrivers
