Recently purchased a Scag Freedom Z zero-turn mower for my 2.5-acre yard. Scag has 26-hp Briggs ELS engine with the updated canister air filter that solved the air intake problem on these engines. Anyhow, I changed oil at recommended 5-hour interval with Castrol HD 30-weight. I plan to run the Castrol for 50 hours and then switch to a stash of six quarts of SJ rated Pennzoil Synthetic that I was going to use in the mower, changing it every 50 hours, about once a year. Sound reasonable to you guys? I need to make this rig last a long time. By the way, this is my first ZTR mower and I'll never go back to a lawn tractor. I used to roast for almost four hours in the L.A. heat and humidity cutting with the lawn tractor. With the Scag, it takes an hour and 45 minutes.
