OK, last one for the night, and yet another one for the thinking caps..
This house is unlike any Ive seen, even in the similar age range... Instead of having a subfloor of planks or plywood, with the real floor nailed into it, this house has only 3/4" or so planks, directly sitting on the joists.
The floor feels plenty sturdy, it does not shake or deflect any more than in any other old house Ive been in, and there are no issues with the floor... however, its just odd that there is no subfloor in the house. Makes me wary of refinishing the floors with a sander, which will take away material.
Anyway, there is one place where there is an issue. There are beautiful brass hot water radiators throughout the house (except the bathroom which has an original cast iron baseboard heat). The one in the living room (and the one on the porch does this as well but to a lesser extent) is sinking the floor down under its weight. I couldnt get a great pic of it, but perhaps you can see the floor planks bowing a bit.
SO, I need to redistribute the weight and support it, so that it does not ruin the floor or fall through! Though it gives no signs of doing so, I want to get everything done right, so Id like to try to take care of this.
SInce the radiators are up against the walls, I cant easily nail supports of any type to joists on two sides. I can only attach it to a joist on one side.
So my thought is this: If I get a piece of 2x10, and place it up against the floor under the radiator feet, and then slowly raise it with a floor jack, then I can get the floor back to somewhere near its original position, and then use that 2x10 under the floor planks, supported by two 4x4 or 2x2 pieces of wood extending to the ground to provide support underneath of the radiator feet. This ought to remove some load from the floor and joists, and I can use the 2x2 or 4x4 as the basis for some storage or a shelf in the basement, which isnt a bad thing at all.
So, essentially, I'd have a 3-D 'T' consisting of a 2x2 (or 4x4 if I want to get fancier) and a 2x10 laying parallel to the floor, wedged in to transfer the weight of the radiator on the 3/4 inch floor, to the basement floor, thus not ruining the wood floor by giving way so much under the weight of the brass hot water radiator.
Good idea? Bad idea? Any suggestion?
Thanks again for all the help... I hope the pics work.
JMH
