Sirius Radio - no audio
Burleson,Texas
I have a 2009 Edge SEL that has a factory installed Sirius radio. I was sick and didn't use the Edge for 6 days and the battery drained to zero from a parasitic load. I charged the battery to about 90% and went to a Ford dealer for a battery check and charging system check. Everything checked out OK. During this time my Sirius subscription expired. Called Sirius and they sent a refresh signal. When I select Aux for the Sirius I can change channels and i see the satellite icon but i do not have audio. Sirius advised me to do a Master Reset. The Sync booklet that came with this vehicle provided instructions for performing the Master Reset. The Instruction discusses phones but nowhere in the Sync booklet is Sirius mentioned.
Will a Master reset restore the Audio?
Is there perhaps an issue with the radio that drained the battery in the first place?
My dad's girlfriend has a Maxima that kept killing batteries. Turns out it was the radio, pulled the fuse and it's been fine for quite a while now.
