Hi.
Winter is coming...
And car's gearbox isn't happy about it.
I used to have hard downshifting problem with manual transmission. There is no Dedicated MTL / STF in my country. With recommendations of some friends here, i decided to use Motul 75-90 GL4/GL5 Fully Synthetic transmission fluid. It really helped a lot. Never had with issue after using Motul.
But since it is getting colder here, in the mornings, it grinds when i try to shift to 2nd gear. Once gearbox is warms up fully, it becomes Ok.
If this won't damage the transmission, its ok for me too. But, since the issue seems to be related to oil viscosity, Would you recommend to go for Ravenol 75-80? (Or 75-85) Would it cause any problem at hot summers ?
It is OPEL's F16 Gearbox.
Winter is coming...
