Originally Posted By: zeng
Spot on, Or
It makes perfect sense for OP to use an easily available 85W90 grade (and probably at far lower cost) as long as ambient temperature is above -12*C during first moving, never mind if Azerbaijan winter could dip below -12*C at times.
Higher MOFT from an 85W90 provides stronger components wear protection.
Hi Sir. I am currently using
Favorit Gear GL-4 SAE 80W-90 (3$/L. I coudln't find any other GL-4
) (When i search for the oil name at google, i can't find any information about the product itself. Actually i can not even find the product itself on the internet. Possibly it is the worst quality oil.)
in the morning it shifts even harder. Ambient temperature is 15 C.
So i am worried that, if 80W90 has shifting problem during the cold operation, then 85W-90 would also have such problem. Unless current problem is related to oil quality, rather than the viscosity
Anyway, i will give a try to Liqui-Moly. Let us see what happens.
I have found Redline MT90 from Russia. Will be buying from there if can't find anything suitable here
