Should I change Oil Weight ( Texas Summer )
TEXAS
I currently use 5w30, which is what my truck recommends. I heard it would help
if I changed I to 10w30. Is this true? and how so?
Facts:
2002 Silverado
4.3 V6
190,000
OIL CURRENTLY USING : Mobil 1 HIGH MILAGE
5w30
Oil Filter MOBIL 1
The oil temperature is largely independent of outside air temperature.
Also, it would still be the same 30 weight when hot. Keep using Mobil 1 High Mileage 5w30, that's some good oil all year round.
Help in what way? What problem are you trying to fix?
I doubt that old-school GM motor cares that much about what it has in it. I'd run 10W30 if it was on sale, but only for that reason. 10W30 and 5W30 are the same hot viscosity.
Don't know where you are, I know Texas can get some cold, but I doubt it gets cold enough that 10W would be an issue. So it ought to be fine for year-round usage.
I know there used to be issues with high levels of VI's with large splits on the winter weight vs hot weight, but that was in the past.
IIRC you run pretty short OCI intervals (according to your other thread, 3k usually, and 5k very recently), so I'm not sure what is gained by over-thinking this. Not unless if you are planning on lengthening your OCI.
Not only would I change the weight, but I'd also change the brand.
might as well try wd-40 then, I heard it lubricates real well!
I'm surprised the guy isn't having noise issues. He must have a loud exhaust and can't hear all the ticking going on.
Horse hockey Merk...quit trolling.
Do you want me to go get that link?
I'll get that link if you want me to.
I got my finger on the button right now.
Do you want me to go get that link? I'll get that ink if you want me to. I got my finger on the button right now.
Oh please. I used the thinnest version of M1 in a 5.4L and had none of the "noise" you are attempting to describe.
That's what I thought you'd say. I knew you'd back off as soon as I threatened to post the bombshell BITOG Custom Search link. Probably scared to 1/2 to death.
+1....Continue to use 5w20. IMO....There will be no advantage to switching to 10w30.
If it isn't broke, don't try to fix it.
BTW, OP ignore Merk. He thinks 10w30 is a "miracle" oil that will fix every problem known to man! LOL
Not if it's Mobil 1 10w30! You try to run that and you're asking for trouble.
Facts:
2002 Silverado
4.3 V6
190,000
5w30
Oil Filter MOBIL 1
10w30 and 5w30 will perform EXACTLY the same in the summer. Its in the winter that the 5w30 will (possibly) flow better when you first start it. But honestly, it doesn't even get cold enough in most of Texas to show the difference.
10w30 is an old spec oil- very few manufacturers have recommended it in the past 20 years. Some (me included) have a hunch that oil blenders 'throw away' their poorest base stock at 10w30 since its so easy to meet the spec with just a few viscosity modifiers. But that's not to say that there aren't also really good 10w30s out there
Go 5w30 or 0w30 year-round. More of a known quantity regardless of brand/sub-brand, etc.
He uses 5w30.
I'm convinced that "Merkava_4" is really a simple AI program that just spouts anti-M1 nonsense every time the topic comes up. An AI that's obviously devoid of a learning subroutine...
I suggest Rotella T6 in 5w 40 for the warm months. Ignore those who will tell you how your engine will shudder and fail because you used 5w 40 in your 100 degree summers. FOr those who claim that "oil temp always stays the same" I suggest that may be true until the cooling system is maxed out on a killer summer day in the south.
