Originally Posted By: FrankN4
JAG
No matter what oil you use for any purpose the ideal viscosity that provides the ultimate lubrication, that is TOTAL bearing surface separation, and at MINIMUM power that is consumed by the lubricants viscosity (MINIMUM TEMPERATURE RISE) occurs ONLY at ONE combination of:
SPEED
LOAD
TEMPERATURE
Under ALL other combinations of the three factors, the lubricant is NOT IDEAL."
Very true.
THE BELOW IS FROM ABOUT 2004 AND MAY BE UPDATED BUT IT SHOWS ORIGIONAL THOUGHT.
I replaced its contents with dots for brevity. That info. did not seem like accurate info. to me.
My truck engine is an American "Bubba" engine; cast iron block V, in block cam, pushrod, rocker arm, 2 valves per cyl. It might possibly see 3000 rpm on extremely rare occasions. There is a realistic possibility that it will go through its projected service life of 200,000+ miles without ever going to 3000 rpm. It will see 70 MPH, about 1700 rpm, but never faster. It will haul a full camping compliment over the Smokey Mountains of TN and NC 3 to 4 times a year, 78F to 100F.
From the above site, they also said that engines that run at lower RPM need a thicker oil than engines that run higher RPM. They said engines that have oil temperatures higher than the 100C/212F need a thicker oil. They said engines that are heavily loaded need a thicker oil.
Yeah, less speed between parts decreases film thickness and a more viscous oil may increase it. Higher oil temperatures reduces viscosity. Using more viscous oil may increase oil temperature but not enough to bring its viscosity down to a less viscous, cooler oil. Yeah, higher loads decreases film thicknesses.
If I had a 30 grade, 5W or 10W, that had a HTHS of 3.5 and a 40 grade, 5W or 10W, that had a HTHS of 3.0, would my engine be better protected by the 5w30? What if the oil temperature hit 230-240F? I actually use a 15W-50 that has a 100C cSt of 18 and a HTHS of 4.56. Why would it not be better to use an oil that had both a high HTHS(3.7 or better) and a high 100C cSt(12.5 or better) Please, this is a real question, not a response. I don't know. I do know that 15W-50 has taken everything we own which includes a Chrysler van that called for 5W-20, now about 114,000 miles, to compacts with DOHC 4 cyl that sometimes see 6000 rpm, well over 100,000, to my Toyota which called for 10w30, now at 300,000, to my Cavalier, which called for 5w30, to just over 203,000. Was it the viscosity or the HTHS that gives such long life to these engines? I am thinking either viscosity or a combination of viscosity and HTHS.
In the early days of motor oil there were only straight weight oils and there was no need to do HTHS tests because it was nearly linearly related to kinematic viscosity at 100C. IOW, they could be equated by a simple constant. Viscosity index improvers were developed which causes this simple relationship to not hold. Oils with them have viscosities that depend on shear rate (among other variables as do straight weight oils). They increase kinematic viscosity more than HTHS viscosity; an oil without them having same kinematic viscosity at 100C as one with them will generally have a higher HTHS.
I wish I had more time to answer all of your points/questions, so if I didn't answer sufficiently, I recommend you read the threads in the Interesting Articles forum.
