Lead shot will not wear rifling. The lead in shot is no different than the lead in solid projectiles. However, if you shoot enough lead shot in a rifled barrel you may get some leading. If you don't know how to remove leading without leaving scratches in the bore, then don't shoot lead shot. If you have bronze wool to push the lead out, then shoot as much lead shot as you want. This is probably the reason they say not to shoot lead shot.Over time it wears the rifling
The plastic shotshell will reduce the fouling but leave plastic residue. Its somewhat helped by the low velocity of the .22 shotshell.Lead shot will not wear rifling. The lead in shot is no different than the lead in solid projectiles. However, if you shoot enough lead shot in a rifled barrel you may get some leading. If you don't know how to remove leading without leaving scratches in the bore, then don't shoot lead shot. If you have bronze wool to push the lead out, then shoot as much lead shot as you want. This is probably the reason they say not to shoot lead shot.
This ^^^ I put up Purple Martin houses - don’t want trash birds around that kill other species (raid and break eggs) …I love your Henry - a beautiful classic - but might a high powered air rifle be better for this purpose? By “protecting my bluebirds” are you shooting some varmint?
The real issue is a shotshell in a rifled barrel will likely fire in a donut pattern.. its more for a snake on the ground than picking off a bird.
Edit:
I'd try the primer only .22lr and if those arent sufficient(accuracy) the 710fps segmenting.
if its within 50-75ft the primer only should do fine.
here is a video of a guy shooting drywall with them.
Its basically a .22lr pellet gun with those.
Not possible, it's just an old Dad's tale.When we were kids (yes Jurassic) - dad and his buddies used to tell us the possibility of shot shells in rifled barrels exploding was real. Pellets tumble, clog, bam.........pretty sure now that's not a thing.
Maybe they were referring to 12 or 20g rifled slug barrels..........tales from on old!
You actually want the non-super.Now I gotta find that ammo....
Rand, Thanks!
becareful some scammy sites out thereRand, I had to go on a bunch of “notify” lists. It seems nobody carries it. It will serve my needs perfectly.
Yep, that one that someone sent me wanted zelle and venmo and a $145 minimum order.becareful some scammy sites out there
if they list zelle or venmo as a payment type beware.
Those 710fps CCI's are instock at any cabelas among other places.Yep, that one that someone sent me wanted zelle and venmo and a $145 minimum order.
