I have a couple of questions.. First I only drive short distances towing a 3,000lb GTW. I have two trucks that I use in this manor. They never see highway use. One is a 92 silverado 6.2L diesel that I sometimes keep running most of the day with A/C on. The other is a 00 Silverado 5.3L that has the same conditions but not left running. These are used for Lawncare.
The questions are will AutoRX work under these conditions? The other thing is it might take me a year to run through one cleaning process and I know the diesel can use 2 because it has 195,000 and the 5.3L has 110,000. Does it matter if it takes this long for each process.
The other question is what kind of Oil should I use in the 00 5.3L Truck (110,000 miles). Since I don't drive much should I use Synthetic (I am towing a small load)? I'm going to see if I can get lucky on the Pennzoil deal at HD tomorrow and I'm unsure what I should stock up on. This is a new truck for us and the previous owner said he switched from Synthetic that it came with to Dino because he had a slight ping and it went away with Dino.
Oh.. I also use synthetic 10w-30 in the mowers, could I go to a 10W-30 in the 5.3L in the summer. I currently use Amsoil HD synthetic diesel oil in the mowers but I am thinking I might just switch everything to Pennz synthetic 10W-30 except for the 6.2L diesel.
Thank You
Thank You
