- Joined
- Apr 13, 2013
- Messages
- 3,223
Say you pull up to a shop for an oil change and they adjust your tire pressure as well. Your tires call for 32 PSI but are found to be low with only 28 PSI - and this is when they are warm after driving. The shop airs them up to 32 PSI and you go off on your merry way.
The 32 PSI spec is for cold tires so your pressure is still going to be low after leaving the shop. This has happened to me many times after an alignment or balancing. Though, in defense of the shops, it is difficult to account for PSI increases after tires warm up - especially when they were low on air to begin with. This is why I double check the pressure once the tires cool down at home after a repair.
