If you would like to know more about tires, our very own @CapriRacer has a website that is really informative and helpful. Spend some time there, it will be worth it, I promise.Thanks. The tires are great,and without any load and with the upgraded general springs ride much rougher which makes knowing the minimum pressure more important.The extra capacity of the springs keep the back from sagging too easy and affecting headlight aim on long trips. I have a lot of info now,funny how much I didn’t know about tires but better late then never.View attachment 210746
A buddy does that on his F250 Super Duty. His tires last longer.we only put load range E tires on our half tons. we have had no issues running an 80PSI rated tire at the 40ish psi rated in the door jam.
at 80PSI with no load in the truck, the centers should be wearing incredibly fast...A buddy does that on his F250 Super Duty. His tires last longer.
Not sure my dental work will last at all with that truly horrible ride. It feels like there are no springs at all. Like it’s going to shake the fillings out of my teeth…
I would run his truck at 40 PSI and buy tires more often if it were mine…
They wear evenly across the tire at 80PSI.at 80PSI with no load in the truck, the centers should be wearing incredibly fast...
for 3/4 and 1 ton pickups with no load, i like 65psi all the way around and rotating every 5 k. these trucks are rough on tires.
interesting, F250's arent that much heavier than the silverados we run and at 80 if the trucks arent loaded destroys the centers of the tires. im glad it works though! i couldnt imagine riding around on 80PSI 24/7, my back/ neck would be worse than it already is.They wear evenly across the tire at 80PSI.
Currently, he has the Michelin LTX. His truck is hard on tires. The super duty with the diesel is a heavy beast, and it eats tires. Michelin, Goodyear, General, Cooper, all of them. He wears them out, evenly across the tread, at far short of the warranty miles on every brand he has had.
When he ran them at 40 PSI, the shoulders were worn down long before the center. So, clearly, 80 PSI is the correct pressure for tire wear, but ugh, that ride…
In fairness, he’s a retired school teacher. He’s budget conscious, and in his position, I would probably run 80 PSI as well.
What I read here is LT(E) on 1500’s with 40 psi …at 80PSI with no load in the truck, the centers should be wearing incredibly fast...
was a reply to Astro with his buddy with a F250, i had already posted my opinion to the OP's question.What I read here is LT(E) on 1500’s with 40 psi …
The last time I did that I ran 45 psi and reached 57k on the better GY Wrangler (Kevlar) … (tread was deep - but, rock chipping)
trucks normally run into driveshaft limitations well before tire speed ratings.I hate to change the subject but can I ask another question about the e range regarding speed rating. My original wranglers View attachment 210753had a 114 rating and when dynoing the ram I am at eye level. Will this upgrade to e range at least make my chances better to come out unscathed because I have another dyno tune coming up for headers and exhaust.
