Tire pressure advice
Yeah watch out for the forbidden pretzel before you worry about shredding a tire.
You can run e rated tires at the same pressure as sl rated tires, your max load will just be lower unless you bump up the psi
I will look into the driveshaft question,my tuner doesn’t work with trucks often after seeing how the wires barely reached,but the Diablo canned tune that came with the blower was crap so I let them do a custom hp tune,but still have to go through that again soon.
The maximum inflation of the
18" LTX A/S is 44 psi!!!​
Thanks it probably doesn’t matter but they are 17s and max is 80 cold 3195 lbs cold the original tire was 44 and 2535 lbs
I figured the 8hp70 or differential will go first,I know how modding works,don’t play if you can’t pay.But I never worried about this particular mustang dyno till I saw the truck on it.
