sedan w/ 4 speed auto . This is the SN/GF-5 . Drove 22 miles before taking sample 1/2 way through draining of oil . Used from 9/18/11 ( 35,650 mis. ) to 1/24/12 ( 40,080 mis. ) . Replaced with the Shell full synthetic 5w-30 (SN/GF-5) . Always use Toyota ( Denso ) oil filter ( 90915-YZZF2 ) and air filter . Vacuum clean air filter ( topside ) with a crevice tool and the bottom of the housing with a brush about 1/2 way through the oil interval(s) . This run looks quite good . Here's the report from BLACKSTONE .
COMMENTS : Everything continues to look good in this latest report for your YARIS . Wear metals are nice and low compared to Universal Averages , and there are not any signs of contamination . Insolubles are still very low , at 0.2% , showing good oil filtration . The SHELL synthetic oil held up well , with the viscosity and physical properties all in range , and the TBN is still good at 4.0 , so there was lots of active additive left . We don't have any problems to report here .
Mis. on oil : 4,430
Mis. on Unit : 40,080
Sample Date : 1/24/12
Aluminum : 4
Chromium : 0
Iron : 9
Copper : 1
Lead : 0
Tin : 2
Molybdenum : 55
Nickel : 0
Manganese : 0
Silver : 0
Titanium : 0
Potassium : 2
Boron : 4
Silicon : 19
Sodium : 5
Calcium : 2173
Magnesium : 15
Phosphorus : 793
Zinc : 885
Barium : 1
SUS Viscosity @ 210F : 50.8 ( 46 59 )
cSt Viscosity @ 100C : 7.52 ( 6.0 10.2 )
Flashpoint in F : 375 ( > 355 )
Fuel % : Antifreeze % : 0.0 ( < 0.0 )
Water % : 0.0 ( < 0.1 )
Insolubles % : 0.2 ( < 0.6 )
TBN : 4.0
You can compare this U.O.A. to these 2 prior U.O.A.s for the '08 sedan and 2010 3 door for comparison . http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2432431&page=1 . The actual reports for both the YARIS are available at YARISWORLD . Go here , http://www.yarisworld.com/forums/showthread.php?t=38135 . Will need to be a member to see them . This SHELL was $4 a quart at BJs , now it's $3 a quart ( http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2504433&gonew=1#UNREAD ) . Will likely pick up another case ( 6 quarts ) of the 5w-20 sometime next month since these results are fine . Next O.C. would be due in JULY and would use the 5w-20 again during warmer months and possibly get another analysis of it in late December to mid January ( 2013 ) with higher miles on that 5w-20 to see how it holds up .
Mis. on oil : 4,430
Aluminum : 4
Chromium : 0
Iron : 9
Copper : 1
Lead : 0
Tin : 2
Molybdenum : 55
Nickel : 0
Manganese : 0
Silver : 0
Titanium : 0
Potassium : 2
Boron : 4
Silicon : 19
Sodium : 5
Calcium : 2173
Magnesium : 15
Phosphorus : 793
Zinc : 885
Barium : 1
TBN : 4.0
