I have a 1/2 qt. of toyota top off oil thats about 1 year old. It has been on a shelf in my car port outside but not in the rain. The bottle is covered in dust but the cap has been on tight.
Safe to use?
Safe to use?
Well - ChevronTexaco oils come with production date codes.quote:
Originally posted by tblazed:
If shelf life is truely an issue, seems the oil companies would need to put an Expiration Date on the container.
I've used lots of oil over the years. The color has varied from pale straw to root beer, and there was no correlation with time. "German Castrol" is green. I've seen differences in identically labelled bottles from different production dates.quote:
Originally posted by 2004 F150 4x4:
The older oils were darker than the new light honey colored oils. My guess is more additives/lower quality base stock vs new oil with less additives but better base stock.
Dave
Even with Group I oils, there was wide variety of color in the finished product. The biggest problem with moisture is probably once a bottle is opened; I'd think there might be a problem with large half-empty drums stored for a long, long time. As for cracking a bottle cap, I've got lots of empty bottles (ready to store used oil) with extra bottle caps. I'm just sure not to break them.quote:
Originally posted by Ray H:
One reason the older oils were darker is they used Group I base oils - MUCH less refined than Group IIs. As to the allegedly complex issue of moisture in sealed motor oils reacting with the additives, then, why, oh why, do the MSDS sheets, the "bible" of the finished product characteristics put out by the blender, ALL categorically state that the finished products are stable indefinitely at normal temperatures? (and, the amount of moisture in factory-sealed bottles pales in comparison to the amount of moisture that's introduced in use . . .) Who the sam-hill is Kathryn Carnes and what are her qualifications?Finally, go cautious about snugging down the bottle cap excessively - yours truly cleverly managed to crack a cap once doing that. Needless to say, the crack did NOTHING to enhance the original seal . . .![]()
This is oil, not fresh meat or produce.
