Hi all,
On my property I have a detached garage, I'm thinking built sometime around the 60's, and added on to the side there's a 3-wall workshop. It uses the exterior wall of the garage as in interior wall to the workshop. The roof is flat with not much pitch and over the years, despite attempts to repair it, water has gotten in and wreaked havoc on a lot of the structure. Two of the ceiling joists are more than half way gone in some spots due to rot. Being that this can't be repaired, we made the decision to demolish the workshop.
I've rented a dumpster, cleaned out the inside, removing lots of waterlogged/rotted wooden shelving and workbench, etc. I've got it down now to mostly bare wall studs and exterior sheeting and I noticed that, reading around, it says that the preferred way of taking down a building like this is to remove the roof first. In this case, even getting onto the roof will be a significant safety risk, so now I'm not sure which way to go with it. I've started cutting out sheeting between the studs to have less bulk once I start taking the main structure down but am not sure if this is the correct way to proceed.
Anyone have experience with this?
