Alright, here's the autopsy. Very good assembly quality, counted 56 pleats! There is a metal crimp seam on the inside facing the inner tube like how many PG filters are assembled. Media element height is 2 inches tall from endcap to endcap. As expected the can is thick like many PG made filters and comes with a coil spring.
Since this is a multi-vehicle spec filter it's bypass rating isn't going to be as high as a Subaru OEM one.
I measured a opening valve diameter of 3/8" of an inch and valve starts to crack open when applying 2 or more pounds of force. Estimating around 18 PSI when the valve starts to open.
Its sightly taller than both the Toyota and Subaru OEM filters roughly 3-1/8" inches high. Also fits on the same filter wrench cap as the OEM filters, 80mm 15 flute size.
