My 2007 Honda Fit has needed to have 3 wheel studs replaced; two on the passenger front axle and one on the driverside front.
I found the lug nuts on these “bad” studs to act as if they were crossthreaded (they would break loose, unscrew a few turns, then lock) when attempting to rotate the tires during oil changes. Therefore, the passenger side issues were found 7,000 miles before the driver’s side. I’ve had the studs replaced and all is well, but I’m curious why this is occurring as I’ve never experienced this issue before with other vehicles (Honda and otherwise).
The guy who drives the airport shuttle where I park my car is also a mechanic (certified Ferrari to boot!) and when talking to him about this, he mentioned that heat could be the issue and that my wheel bearings could be heating up, causing the studs to heat up, expand (and contract), thus warping them.
Curious if anyone else has experienced this or has thoughts on the theory.
Cheers,
K
