I success use seafoam almost every old car I had in the past, accept new car, 1/3 in gas , 1/3 in oil 1/3 in intake using hose at brake boost.
i did seafoam on my 1995 mustang gt 5.0 , everything went well, after 20 min, i turn on the car, it idle fine, i rev it up to 1.5k rpm to 2k rpm, and some how it stuck at 2k rpm ! and heard loud sound like leaf blower on right side of engine, sound like massive air leak. I drove for 5 min, rpm drop down as soon i put in gear and if i idle, it spike back at 2k rpm.
I hook everything back on right, I only take out 1 hose and and put back in same spot, i have feeling that either
1: Seafoam is break down an old gasket and created a air leak
2: seafoam break down old dirty stuff and got stuck at the Idle air control .
im thinking spay some carb cleaner around TB, see if idle is drop, and gonna check the butterfly to see it stuck open and mabe need adjust the screw. I havent have time to do that yet, i want to see if any one have same experiment as me. thank you and have a nice day.
