You say less mess - I assume you don't care about the color of the grease and just want a product that says in the pins better. Compared to a lithium complex grease with 3% moly any of the general purpose greases from Schaeffer will stay in the pins better and reduce your grease consumption. The 229 grease is very tacky and is not recommended for use in wheel bearings or electric motors. If don't mind having multiple greases in stock using an "extra tacky" grease like 229 or 238 in the front end loaders would work very well.
If you are looking for one grease to use on everything on the farm I think the 219 is a better choice.
