Choice between only two greases
NH
I am wondering if I would see less pin and bushing wear on my excavator if I use Schaeffers 238 Ultra Supreme Waterproof Grease vs TSC Traveller 3% moly grease? I realize the Schaeffer will last longer but I can make up for that with a shorter grease interval. Schaeffers is $8 per tube vs TSC at $3 per tube on sale. Please keep it to these two greases. Thanks
for a sliding load I would think a 5% moly grease would be even better?
And the schaeffers is 5% so the answer is yes.
Of course you could just buy a different 5% grease and it would be better than the 3% too.
edit: I'm showing no 5% moly grease at TSC..
you could go for https://www.amazon.com/Amalie-Pro-Tac-Moly-Grease/dp/B008QDIAA0/ref=sr_1_3?ie=UTF8&qid=1514907233&sr=8-3&keywords=5%25+moly+grease
its 10 tubes for 42$ shipped.
The Traveller grease is 3%. I guess the question is whether %5 moly will reduce wear significantly more. The Amalie link is a good price for %5 moly. Not sure if the Schaeffer is worth twice the price.
A lot more to grease than moly%
The Schaeffer's grease will stay in the pins/bushings long after that TSC grease is gone. You can grease more often, but which pays more...running the machine, or running a grease gun?
I must say, "You make a very excellent point, SIr."
I'd use the Schaeffers.
