It's been a while since I went down this rabbit hole and unfortunately due to my home situation I just don't have a ton of hours to dedicate to research right now. I appreciate your grace in answering my question below. Just let me know if you need more information.
I recently installed a blower on my 2008 LS3 C6 which has about 55k miles on it. I'm running around 11 lbs of boost making 694 to the wheels. Running stock rings, pistons, rods, and crank. I drive it pretty hard most of the time. I never drive it below 45 degrees outside because of the tires. I put less than 5k miles a year on it, so oil change intervals are irrelevant to me. I've been running PUP 5w30 for years, but I want to make sure I'm protecting from engine wear as best I can. So, the big question now is (and I know it's a loaded question), do I stick with PUP or is there a better wear protection oil I need to consider based on the age, power, and OCI? How about weight?
Thanks all!
Thanks all!
