Originally Posted By: Astro14
If external manual safeties are so effective at making guns safer, why don't revolvers have them?
Revolvers require at least twice the trigger pressure to fire it in single action.
A double action revolver when cocked doesn't take as much trigger pressure to fire. Running around with a revolver chambered and cocked all the time is basically the same as a chambered and cocked Glock or similarly designed gun.
You've got this all wrong, and I'm left wondering where you get your facts.
"Revolvers require at least twice the trigger pressure to fire it in single action" - well, no, they don't.
I meant double action ... just like the red sentence would elude to. Surprised you didn't pick that up with logic, but instead you'd rather start off with an insult.
A Glock typically takes about 6-7# out of the box. Some department specify a different connector (the "New York" trigger") which puts the Glock about 8#.
My S&W Model 15 takes about 12# for a full double action pull. Roughly double the pressure that a Glock takes, but that's for a double action pull and that's with an unmodified S&W. For comparison, My wife's Beretta 92 takes about 12# for double action, and about 5# for single action. My Sig P227 and S&W 5906 are about the same; 12/5 for double/single.
So, a single action revolver pull is much lighter than a Glock.[/quote]
Looking at your examples above, it shows what I was eluding to about double-action mode.
Glock 15 - 6# double action
S&W - 12# double action
Beretta 92 - 12# ... 5# single action
Sig p227 - 12# ... 5# single action
S&W 5906 - 12# ... 5# single action
Well there ya go ... pretty much what I said. A Glock is basically in the same "ready to fire" state as a fully cocked revolver within +/- 1 lbs of trigger force. That's really not a convincing counter to my viewpoint.
The other claim "There are way more pistols in the world with a real trigger safety than there are not." is similarly unsupportable. If by "real trigger safety", you mean an external, manual safety (like exists on the Beretta 92, or on a Colt 1911), then I don't buy that claim.
The Glock has a trigger safety, that requires you to press the trigger to fire the gun. The gun WILL NOT FIRE without the trigger being pressed. That's a "real trigger safety", but I think you mean the former type.
Yes, a real trigger safety is one that will not allow a trigger pull to discharge the weapon. I knew someone would bring up the comment in red above. The "trigger safety" in not a real safety. It's a mechanism to prevent the pistol from discharging if it hits the ground in such a way that the inertia of the trigger might cause it to move backwards and discharge the gun. It's simply a mechanism that unlocks that feature when a finger is press up against the trigger. It in no way pervents the gun from discharging when the trigger is pulled by a finger. That's what a real trigger safety would do. So don't know why you claim the Glock or similar style trigger designs are a "real trigger safety".
The most important safety is between the ears of the operator.
And that's what failed in this case.
Not the gun.
I agree with you that the best safety is between the ears. And I have never said it was the guns fault (go back and re-read) ... only that IF that gun had an engaged real trigger safety (ie, mechanical thumb safety) it would NOT have discharged when he did the bonehead move and picked it up by the trigger. Wouldn't you agree with that?
