My 86 chevy k30 is nearly all metric
Small & Big Block Chevies are the reason I own so many standard tools.
By standard do you mean SAE?Small & Big Block Chevies are the reason I own so many standard tools.
Same reason spark plug threads are metric even going back almost 100 years and the socket size in in SAE. The model T was 1/2" pipe threads.The rachets for my metric sockets sets are in inches: 3/8 and 1/2. Why is that?
USA ratchet makers were the most plentiful in olden days? Although they also fully understood metric. Ratchets are from 1/4 to 1 inch in 5 common sizes. The world gets used to it.The rachets for my metric sockets sets are in inches: 3/8 and 1/2. Why is that?
NLZ is the brand name of NL&Z Import Company in Australia, and the description at https://www.nlzimport.com.au/products/mcw-7_c?_pos=4&_psq=Multi-Fit&_ss=e&_v=1.0 shows the same images you included.
Lowes retailed a line called Multi-Fit at one time per https://www.amazon.com/Kobalt-14-Piece-Direct-Ratchet-0607975/dp/B00QDBD38G that was made in China.
Jonnesway is an established tool manufacturer in Taiwan https://www.jonnesway.com/en_US/company/ and sells on the web at https://www.jonneswaytools.store/products - a wider selection of wrenches and socket sets are sold https://www.ebay.com/str/atptoolsparts
Multi-Fit tools are also called Super Tech, and are sometimes listed as Metric so you have to rely on the part number prefix to be sure: Sockets S68, Wrenches W84, Ratcheting Wrenches W86.
The Metrinch sockets and wrenches that hrv mentioned were US-made way back when but are now made by Cendai Taiwan which boldly promotes the patent by Surelabs USA on its packaging which has long since expired (https://patents.google.com/patent/US4100824A was filed in 1976).
The Metrinch patent reads like a variation/extension of SnapOn's 1965 patent for flank drive, and the Multi-Fit looks like a one step further.
Organizational inertiai wonder why?
Take a caliper and measure 16 vs.5/8,or 19 vs 3/4,you might be surprised how close they are.I'm in the rust belt,I use what fits the best,not concerned with the marking on the toolI have some inch sockets that they stamped the metric equivalent on them. A number of them can be used on metric, like 3/4” is very close to 19 mm. I still find inch easier to guess at and be right.
Which is hilarious because the threading is often metric, often 14mm. My Dad had a 1940 Ford flathead that had metric threads tapped for the plugs! That car was so old, it predated the use of Phillips head screws.Honestly I think the reason no one's bothered to do anything metric about plugs is because 9/16" is basically 14mm, 5/8" is 16mm and 13/16" is 21mm
Quite often you'll even see plug hex specs listed as both, say, 5/8" and 16mm.
I think your 5/16" experience is just the nature of the manufacturer of your sockets and/or fasteners. Even if both your sockets are the same brand one could have been made on a Friday and one on a Tuesday.Which is hilarious because the threading is often metric, often 14mm. My Dad had a 1940 Ford flathead that had metric threads tapped for the plugs! That car was so old, it predated the use of Phillips head screws.
I use a 5/16" on 8mm headed fasteners all the time, it fits tighter/ better. Toolmakers and fastener guys deliberately leave a lot of slop in the sizing, too much IMO.
I was surprised that every bolt I have touched so far was metric. It is a CUCV 6.2 Diesel
Yeah, I am not sure. The starter bolts were 14mm, and the front bolt for the support braket were 12 I Think. Alternator was 15. Weird. Of course, they are all close in the `14\15mm\9/16 world, I generally pick which ever fits tighter.I use standard in conversation.
I think the starter bolts, bellhousing bolts and likely the engine stand bolts are SAE on a GM 6.2L Diesel.
well, the pump bolts were 7/16I use standard in conversation.
I am with you.Those are easily convertible to 11mm & 24mm.
On most 80's & 90's GM vehicles....You might need 3/8", 1/2", 9/16" & 11/16" for certain engine/transmission related repairs.
14mm is a little to tight on 9/16" headed fasteners in my opinion, 13mm is to loose on 1/2", & no replacement for a 3/8"
I have a Metrinch set that I bought in the 90's that I use all of the time. It's my most used socket set because of the ability to work on both SAE and Metric. I actually used it today at the salvage yard. I also have the 76 piece set that I bought years ago as a back up.I have a Metrinch tool set that I got in the 80s and still use today...It works on both....
What is special about these minus the ability to be used on both? Are they good for rusted fasteners? I first heard about them ~10 years ago from a junkyard employee who swore by them.I have a Metrinch set that I bought in the 90's that I use all of the time. It's my most used socket set because of the ability to work on both SAE and Metric. I actually used it today at the salvage yard. I also have the 76 piece set that I bought years ago as a back up.
