Thought I should report something from the Society of Automotive Engineers technical papers on bypass filters.From SAE #710813 we get an increase in lifepan for the following components switching from a 60 Micron FF to a 60 Micron FF with a 3 Micron bypass: Top ring +900%, second ring +562%, oil ring +422%, rod bearing +300%, main bearing +261%. This was from a Cummins motor test, not a filter manufacturer.From SAE # 930996 we get a test comapring a 40 micron FF to a FF with submicronic bypass (centrifugal):top ring +792%, second ring +1000%, oil ring +229%, connecting rod bearing +750%, exhaust valve components +282%, piston pin +1000%, turbo bearing +1000%.This was from Glacier, a filter manufacturer.According to SAE 2001-01-0867 we can expect an absolute 2 micron bypass filter to remove several orders of magnitude of transmission fluid contaminants compared to a conventional automatic transmission.If I read the charts right this implies a 300% improvement in the lifespan of the transmission. There are about 20 papers relating to filtration efficiency in engines. One of the most important was done in 1946. This paper showed that full flow filtration cut engine component wear in half compared to the bypass only filtration that was common at the time. They should have kept the bypass when they went to full flow!Several other papers stressed that filtering below the 5 micron level , and even into the submicronic level resulted in large improvements in the lifespan of most engine components including the timing chain, and seals.
