RxP Gas Kicker
VA
I just saw this at autozone today, and I was curious if anyone has tried it. Made of Petroleum Distillates. $7 for a 2.5 oz bottle. 1 oz treats 10 gal. of fuel.
RxP Gas Kicker
"The next generation in fuel technology. The first product to ever make claims such as "significant reduction in CO, HC and NOx emissions," and be able to back them up with independent laboratory 511 Hot Start Tests. RxP Gas Kicker also increases horsepower. Kicker works equally well in gasoline or diesel engines and makes reformulated fuel burn like high grade gasoline. One ounce treats 10 gallons of fuel."
"INSTRUCTIONS FOR USING RxP WHEN TAKING AN EMISSIONS TEST
NOTE : The engine "absolutely" must be getting enough fuel and air for RxP to work properly.
Before you add RxP to your gasoline, check for apparent vehicle defects. If the vehicle has mechanical problems they should be repaired according to manufacturer recommended specifications before taking an emissions test.
1. Fill the gas tank and add one ounce of RxP per ten gallons of gasoline. Be sure you treat the gasoline that is already in the tank.
2. Drive the vehicle allowing enough time for the engine to be de-carbonized (most vehicles can be tested 30 minutes after adding RxP, but for best results run a full tank through the vehicle). If the vehicle is inspected for emissions before the de-carbonization process is completed, the emissions may go up. Do not be alarmed. The de-carbonization takes time, especially on engines that have excessive build-up.
3. Fill gasoline tank and add one ounce of RxP to ten gallons of gasoline.
4. Change oil, oil filter and air filters. RxP will not work if the engine is not getting enough fuel or air (oxygen).
5. The engine is now ready to be tested, however we suggest that before taking an emissions test you turn off the air conditioner and run the vehicle long enough to insure engine is raised to normal operating temperature.
Note: RxP is less effective in air cooled engines that are not equipped with an EGR system. The emissions should still be reduced significantly, however because of the design of some of these engines the emissions levels may not drop to a level low enough to pass some emissions tests.
In an informal survey conducted by RxP Products, we learned that 98% of the vehicles using RxP passed federally mandated emissions tests on the first attempt. The 2% that failed did so because:
1) they failed to read and follow the instructions,
2) the vehicle had severe mechanical problems (such as a faulty exhaust system, cracked head or manifold, defective carburetor or other apparent serious malfunctions), and
3) the engine was not getting enough fuel or air."
If it's the small red bottle, I've used it in the past-on 80's GM V-8's-they seemed to run better, but only with the additive in the tank. Last time I checked it was discontinued
It is the small red bottle, picked one up from auto-zone yesterday. I was going to do a compression check before and after, but IDK. Dont think it would do enough to show a difference. I like on there website they have before and after pictures of a piston top, and the before is the worst piston in motor and the after is the best.
I was just curious if someone could look at the MSDS and tell me if it competes with RL or AMSOIL, or if it could even live up to its bold statements for that matter.
Thanx
