Sounda like a good way to blow out engine seals,not worth it at all.
Quote:
I run my Maxima a 1/2 qt. over to prevent oil starvation in hard cornering. I don't want another spun rod bearing.
Quote:
HOw much lateral-G can you run on your Maxima to "induce" oil starvation?? 3G??
Quote:
Both cases involved bigass Cummins engines (an 855 and an N14).
Quote:
In some engines designs it doesn't take much, a long on/off ramp will do it.
Quote:
I'd be about 1/4" over full on the dipstick, and I'd get some oil weeping from the dipstick tube (at the block, not at the top!) and the rear main seal.
Quote:
On my 1995 Ford Ranger with the 4.0L V-6, the manual says that with an oil and filter change, capacity is 5 quarts. Yet, after an oil change when I put in 5 quarts, I'd be about 1/4" over full on the dipstick, and I'd get some oil weeping from the dipstick tube (at the block, not at the top!) and the rear main seal.
Yet, if I added only 4.5 quarts after the oil/filter change, I'd be right at full on the dipstick and I wouldn't weep any oil from the rear main seal or the dipstick tube. On this engine, there would be NO WAY I could run a quart over, it would just ooze it all out. I should note that this truck has nearly 120k miles on it...
If you wanted to add oil capacity, I'd add an engine oil cooler and/or an over-sized oil filter. I actually looked at the over-sized filter option for my Ranger, as I agree that extra oil capacity is a good thing. Problem with the Ranger is that the over-sized filter would hang down far enough I worried about road debris punching a hole in it...![]()
later,
b
later,
b
Quote:
My 99 4.0 also says full at 4.5 quarts.
Quote:
Yeah you could run 6 quarts in there easy.
