Running A Quart Over
Originally Posted By: The Critic
FWIW, my 96 SL2 with 110k is about 1/5 qt low after 1700 miles of city/highway driving. Oil consumption stays pretty low for the first 3k miles, then it skyrockets.
THIS is telling you something about the oil you use. By 3K miles, it's sheared way out of operating temperature grade, and the remaining thin oil is slipping past the rings.
If your weather allows it, switch to a heavier base oil (from 5W-XX to 10W-XX). While/if your starting temperatures are above 40F, switch to a mono-grade SAE-30. You'll REALLY see your oil consumption go down.
