Originally Posted By: CATERHAM
Originally Posted By: FZ1
Interested in trying the 5-20 Castrol EDGE but the product data sheet indicates it is very thin,yet the pour point is not as low as the M1. Guess I'll stick with the Mobil 1 Extended Performance deals,for now.
Check out the 0W20, it is working quite well for me. It is a little "thicker" at 100C than the Castrol EDGE 5W20 is.
A common BITOG misconception.
A higher KV100 spec' doesn't necessarily mean the oil is any "thicker" in terms of operational viscosity unless it has a higher HTHS viscosity. If it doesn't, and in the case of Castrol EDGE 0W-20 and 5W-20, they are likely the same at 2.6cP, then the two oils will have the same viscosity at operating temperature, at least in their virginal state.
But the 0W-20 has an unprecedentedly high VI at 220 vs 175 for the 5W-20, consiquently it is likely less shear stable and therefore actually lighter in actual service.
The info I stated was from a conversation I had quite a while back with a Castrol rep re: 0W20 and 5W20 Castrol EDGE. You are correct about the unprecedentedly high VI @ 220C for the 0W20. But according to the person I spoke with it is the "unique" formula that 0W20 Castrol EDGE has that makes it slightly "thicker" than the 5W20 at operating temps. It also will not shear out of grade, and is well within the specs of a 20 grade oil.
Go easy on my I'm not a scientist nor a chemist, I'm repeating what I was told. It could be a bunch of [censored] but at the time it seemed like the person was telling the truth within the boundaries of what they could say. They both perform very well in applications approved for 20 grade oils was another comment, with two thumbs up for the 0W20 for cold starts and cold weather applications and in hybrid engines.
When asked if a 30 grade oil would protect better than a 20 grade oil, or if it can be used in place of a 20 grade oil, I got the usual reply. Use only what the mfg suggests for your climate and application. LOL Which is exactly what I expected to hear.
