NOw that temps are dropping, I'm beginning to see full benefits of this oil. -20 cold starts, not a peep, no extra strain on other components such as belts etc, previous oil when cold you could hear for a few seconds that whine and noise and or valve train tick, Also using a car starter my mpg's dipped below 10 easily. As I stated when I first filled it, this oils by far gave me the biggest increase in mpg's. I went as high as 19.9 but that was when I pretty much had straight streches and taking back roads at that time as that was my main commute. Settled to 16.2 for stop and go. And for a Jeep that is dam good.
And in all honesty and full disclosure, I also use archoil. And run min 89 but mostly especially in winter 91. After 2 months I can honestly say at minimum this oil is at par if not better than anything you can buy, off the shelf. I was a steady M1 user, few times valvoline. But this oil will be the only oil I ever use. Quiet, smooth, I've converted a few other Jeep owners, and they were flabbergasted. Looking forward to get it tested, and this will be my second UOA. and only because of how impressed this oil has worked out.
I'm not the Tylpe to shove oil or my preferences down people's throats, but Rotella Gas Truck 5w30. You will not be disappointed. No oil I ever used made so much of a visible, and tangible difference. Last year with Mobil 1 Extended Performance not only was it a louder but because of remote start, in which ah max I would and still do start for 5 min only. Mpg was 8.9. And even running remote start and being winter averaging 12.2.
Obviously negative comments will be a plenty.....but just trying to do people a service, I want the best for my vehicle....I have experience, not a dolt when it comes to cars, bikes etc. I'm very in tune with my toys. If you have the opportunity coming up or on the fence or thinking of new oil. Rotella Gas Truck 5w30. If you find it doesn't live up to my hype.....by all means call me out on it.
