The easy way to take the filter out is to find an oversized filter that fits and has the same or higher by-pass rating. The increased filter area will lower restriction more than any brand change and it'll filter better, longer. And it will add total capacity to the crankcase system so you have more clean oil available for spirited driving. Same price usually ...
Engines with larger capacity sump and oiling systems tend to last longer
You want fuel savings, run "greeen" tires (I hate them, but they do work). They just don't stick all that well
Run them inflated well.
Change any incandescent bulb in the system to LED. Lighting ain't free, it takes power to make electricity...
Add flexible front spoiler to get more clean air around the car and less under. Or, lower the car to reduce overall frontal area plus dirty air under.
Reduce cruising speed 10% (say 70 down to 63) it will make more difference than all the oil changes, filters and other tricks you can think of. Air resistance goes up with the Square of the velocity ...
