I’m trying to find what the acceptable rpm range for the B&S 223 engine. This is on my Toro Timemaster mower. It’s this engine
I cannot find what the rpm range is. I want to set it at the highest optimal and acceptable range that’s not going to be harmful to the engine.
Briggs & Stratton Professional Series 223cc Vertical Engine w/ Heavy Flywheel, 25mm x 3-5/32" Crankshaft, Tapped 7/16"-20, 3/16" Straight Keyway | Briggs & Stratton 14D932-0115-F1
The Briggs & Stratton Professional Series 223cc Vertical Engine w/ Heavy Flywheel, 25mm x 3-5/32-Inch Crankshaft, Tapped 7/16-Inch-20, 3/16-Inch Straight Keyway 14D932-0115-F1 has been discontinued.
www.powerequipmentdirect.com
