Originally Posted by lawnguy
Price is not an issue to me. I want the best for my truck
Well, if you want a heavily adorned with OE certification oil that's based with PAO, Ravenol is probably "it". They not only use top-notch base oils, but they actually go out of their way to get all the OE approvals.
What is their very best oil compared to redline 5w30,or the like? Sure would be nice to see a VOA on their best 5w30.
They aren't really comparable. Unlike Redline, Ravenol has OE approvals on their products that contain premium base oils, whilst Redline's OEM-geared lubes are based using primarily Group III.
Ravenol has three different PAO-based PCMO 5w30's:
- DXG, your typical lower HTHS (3.1cP) GF-5 one, that is Dexos 1 gen 2 approved with a Noack of 6%:
https://www.ravenol.de/en/products/usage/d/Product/show/p/ravenol-dxg-sae-5w30.html
- FDS, A1/B1 geared toward Ford, Land Rover and Mercedes. Low HTHS (3.0cP) with a Noack of 8.9%:
https://www.ravenol.de/en/products/usage/d/Product/show/p/ravenol-fds-sae-5w30.html
- VMP, ACEA C3 lube, BMW LL-04, VW 504, MB229.31...etc. High HTHS (3.6cP) with a Noack of 7.2%:
https://www.ravenol.de/en/products/usage/d/Product/show/p/ravenol-vmp-sae-5w30.html
On top of that, they have a number of less expensive lubes in their lower tier product lines.
Ravenol also makes two racing 5w30's which also happen to have OEM approvals:
- RSP, BMW LL-01, MB229.5..etc. HTHS of 3.57cP, Noack of 7.2%, pour point of -60C:
https://www.ravenol.de/en/products/usage/d/Product/show/p/ravenol-rsp-sae-5w30.html
- REP, BMW LL-04, MB229.51, C3...etc. More geared toward diesels. HTHS of 3.7, Noack of 6.2%, pour point of -60C:
https://www.ravenol.de/en/products/usage/d/Product/show/p/ravenol-rep-sae-5w30.html
Probably the most comparable would be the RSP? But even then, it has formal OEM approvals. Interestingly, the DXG, despite being lighter, has the same Noack as the Redline 5w30 and a lower pour point.
