Royal Purple or Mobil 1 SS ???
Raleigh, NC
I have been searching, but did not find what I was looking for........what advantages would Royal Purple have over Mobil 1 SuperSyn?? Or aren't there really any....
quote:
Hi,
Royal Purple has been recently thoroughly
discredited by Patman's used oil analysis.
It's basically only slightly better than
gravel at protecting your engine.
thanks
Jae
Royal Purple has a loyal following in alot of circles, the OTR truckers, racing enthusiasts, ect. Trans and rear end oil are also regarded as good oils. This a good reputable company.
Go to the analysis section and you will see that many oils have a problem. It depends on the engine, driver, weather and other variables.
I can show you bad analysis on most brand oils. And I can show you outstanding ones on the same oil.
Mobil I is also a good choice. Available OTC at most chain stores.
A couple of guys at work use Royal Purple and claim that their vehicles run smoother and get better gas milage. I've been tempted to try it out. I use Mobil 1 mainly because its easy to get and I have had decent analysis results with the SS versions.
WHERE IS THAT UOA ??
quote:
Hi,
thanks
Jae
Go with M1. M1 SS results have been excellent overall. I've been reading every prior analysis posted on this site. 10w-30 especially. If consumption is an issue, mix some or try Amsoil/Redline.
