Royal Purple answer about ATF+4
Louisville
Stanley
Royal Purple is still working on an ATF+4. This is one of those things that is just not that simple. We have the technology to produce an ATF+4. But Chrysler will not give it warranty approval. So at this time we are only going to produce the MAX ATF. You can use Max ATF in an ATF+4 application once your warranty period has expired.
Sorry but at this time we have no plans to produce any 0 weight oils.
Thanks
Patrick Burris
Technical Advisor
Royal Purple Ltd.
1-888-382-6300 ext 241
Direct 281-577-5041
cell 713-705-9201
The above post is in my request about a RP ATF+4 product and about the possibility of RP introducing API approved 9 weight oils.
I don't blame them .I would not make one either .
We have not seen Schaeffers jump in and make a 5w-20 yet either have we ?
Kinda sorta on the same topic .
No. One is about ATF and not having the manufacture recognize it for warranty purposes. Your's is about a smallish oil blender whose main business is industrial lubricants and happens to make a limited amount of passenger vehicle oils in the most popular grades. Since 5W-20 is not that widely used yet it doesn't pay for them to take production capacity away more widely used oils at this time. Or do you mean 5W-20 just bites and only nut cases who hate their vehicles use it
Whimsey
Originally posted by salesrep:
Rumor has it 5-20 is in the works.
Caved in did they ?
Well I had high hopes this was a just a whim that would pass with the auto-makers .
Plastic crankshafts are next
Throwaway cars TBA .
Whimsey ,
It's my opinion you took advantage of my post soley to take it out of context and spin it another direction ... are you bored ?
Almost forgot
Still yet if I were in charge of a smaller company such as RP or Schaeffers or other I still would not make anything for Chrysler .
If history repeats they'll just want something different in a year or so anyway
Why waste the effort which is in reality......money .
I got some technical help from Patrick at RP as well in regard to ATF+4. But somehow I think you are referring to use in an auto transmission. I was looking for an ATF+4 replacement for a 5 speed manual transaxle and Patrick recommended their Synchromax fluid, it has a viscosity of about 7.7 cst. and is suitable for replacement for ATF+4 in manual transmissions, not autos though.
BTW , anyone know the viscosity of ATF+4 ?, is he implying that it is a 0 weight fluid ?. I will be doing a used oil analysis on it in the spring but I would like to know the viscosity range if anyone knows it.
Joey
