Interesting Email from Royal Purple
Originally Posted By: Rohan
U guy mean royal purple is not good oil n is bad? Cause that wht I'm gonna buy for my next oil change XPR royal purple oil. Please help me so maybe I won't buy purple oil.
Royal Purple is good oil. Mobil 1 is good oil. Amsoil is good oil. is good oil. All in the correct application. XPR? Do you really need a race oil?
Quote:
Unfortunately, the 'independent dealers' have not pulled this false information and Amsoil Corp doesn't have the 'stones' to tell them to stop.
That is totally false. This AM I reported the site above to Amsoil. Mid-day I received a response.
Quote:
Paul,
Yes, this is old data that AMSOIL INC. does not support. It will be removed.
Best Regards,
Yes I do cause I have mods can't list too long. Sorry.
400 and 500 HP stock vehicles use Mobil 1 (and can use other street oils). You're exceeding that output?
Originally Posted By: buster
I can't remember the details, but from what I recall Amsoil published a story in their News Letter called "Action News" where an individual claimed Royal Purple was using molybdenum disulfide, which was a flat out lie. They use Moly TDC. Why Amsoil published that is beyond me.
Moly TDC is a great multipurpose additive used by many oils on the market. I believe Schaeffer was using it first, others later followed. In fact, Amsoil jumped on board eventually and started using it.
Thank You Buster
Can I used Mobil 1 0w40 oil? How far can 0w40 can go?
That depends on several factors. What engine and what mods (briefly)? How much HP?
It's a 400cc Yamaha......LOL :)
Thank You Buster
This is one incident I have spoken of that turned me off of Amsoil in the past. I have been called a liar for saying this happened. Glad to see someone else bring it up and back it up.
Hate to get this bandwagon going again but, ive been desperately searching the web to find pictures of engines that have been pulled apart after royal purple use, or test results, etc, to see if it actually is worth the 8-9 dollars a quart. I know I have seen alot of information saying how good it is, but before i throw it in my newly built engine, I always am CERTAIN before i use a product. Anyone have any information like this? What would you guys suggest.
interesting fact, royal purple is API certified despite what some of the forums are saying
http://eolcs.api.org/DisplayLicenseInfo.asp?LicenseNo=0777
Schedule A - License Agreement
Company Name: ROYAL PURPLE, INC.
License Number: 0777 Link to API Licensed Products
Click Here to
View Products
City: Porter, Texas 77365
Country: THE UNITED STATES
Web Site: www.royalpurple.com
Company Information/Background:
ROYAL PURPLE, INC. began marketing licensed motor oil products on August 8, 1995 under a license issued by the American Petroleum Institute. This License and Agreement will terminate on August 8, 2010 unless extended by mutual agreement.
The Certification Marks referred to and licensed under the agreement between API and the licensee are as follows:
Licensee is authorized to display the API Service Symbol on the following products during the period of August 8, 2009 through August 8, 2010:
Brand Name SAE Viscosity Grade Service Category Current Expiration Date
LONG RIDER 15w40 CH-4,CI-4,CJ-4/SM August 8, 2010
LONG RIDER 5W-20 SL* August 8, 2010
LONG RIDER 5w30 SL* August 8, 2010
ROYAL PURPLE 0W-40 SM/CF August 8, 2010
ROYAL PURPLE 10w30 CH-4,CI-4/SL August 8, 2010
ROYAL PURPLE 10w30 SL* August 8, 2010
ROYAL PURPLE 10W-40 CH-4,CI-4/SL August 8, 2010
ROYAL PURPLE 15w40 CH-4,CI-4,CJ-4/SM** August 8, 2010
ROYAL PURPLE 15w40 CH-4,CI-4/SL** August 8, 2010
ROYAL PURPLE 20W-50 CF/SJ August 8, 2010
ROYAL PURPLE 30 CF/SJ August 8, 2010
ROYAL PURPLE 40 CF/SJ August 8, 2010
ROYAL PURPLE 50 CF/SJ August 8, 2010
ROYAL PURPLE 5W-20 SL* August 8, 2010
ROYAL PURPLE 5w30 SL* August 8, 2010
ROYAL PURPLE 5W-40 SM/CF August 8, 2010
ROYAL PURPLE LONG RIDER 10w30 CH-4,CI-4/SL August 8, 2010
ROYAL PURPLE LONG RIDER 15w40 CH-4,CI-4/SL** August 8, 2010
ROYAL PURPLE LONG RIDER 40 CF August 8, 2010
ROYAL PURPLE LONG RIDER PLUS 10w30 CI-4/SL August 8, 2010
ROYAL PURPLE LONG RIDER PLUS 15w40 CI-4/SL August 8, 2010
* - Energy Conserving ** - CI-4 Plus
Originally Posted By: Spawne32
any links? was it a complete disaster?
To the contrary. The cams were in like new condition despite some 30K of hard use as I recall. The Mobil 1 cams shown in comparison at least visually did not fair as well.
I have no pictures to show you but I have run RP for 2 decades and have torn down engines run on it and they were in great shape( torn down for upgrades or because they were at the max # of runs at the drags not due to failure ).
There is no best oil out there but RP is one of the top ones available. It is very good oil. Use it and don't worry.
Oh, and btw, $8-$9 a qt is too high. Go to their web site and use the dealer search feature to locate the different sources in your state and price shop. Try online as well. I am lucky and only pay $5.75-$6.50 a qt through my local source but I have other ones around and the most I ever pay is exactly $7 a qt.
ill probably be buying it by the case through my alarm guy at like 5-6 bucks a quart, question though, has anyone ever run any chemical testing on their max atf transmission fluid? My transmission is full of it now and although I cant be certain but it seems that my average coolant temp has gone up since the full change ( transmission cooler lines run through the radiator). While this could be more cooling system related I was wondering if anyone has had any beefs with the transmission fluid being either too thin or not.
I have never heard of "any" synthetic transmission fluid causing an increase in temp. The opposite generally occurs. Lowers trans temp so thus it would not raise coolant temp.
