I've owned this car for a year and a half, but just got my first oil analysis done. The car does zero commuting and very few short trips. I drive it almost exclusively on the weekends. Some of those weekends involve autocrosses (I think this oil has about 40 runs on it) and occasional track days (maybe 150 miles of track duty on this oil). Although I used about half a quart of make-up oil, that was mostly a measure to reduce valve tick; it probably burned 1/4 quart in reality - well within spec for the engine.
Air and oil filters are both OEM. The air filter is less than 7000 miles old, and of course I change the oil filter with the oil.
I'm interested to hear any comments/suggestions. Here are the results:
1999 BMW M3
3.2L I-6 (S52)
Royal Purple 15w40
Miles on oil: 3363 (April 30 - November 26)
Miles on car: 44,093
Make-up oil added: 0.5qt
Al 6
Cr 1
Fe 15
Cu 3
Pb 0
Sn 3
Mo 119
Ni 0
Mn 0
Ag 0
Ti 0
K 2
B 14
Si 6
Na 2
Ca 4135
Mg 14
P 926
Zn 1182
Ba 1
Sus. viscosity 69.5 [69-78]
Flashpoint 400 [>420]
Fuel 1.0 [ Antifreeze 0 [0.0]
Water 0.0 [ Insolubles 0.3 [
Comments: "Nothing too unusual showed up in this sample. All wear around averages for this type of engine, which is a good indication of normal wearing parts. Universal averages show normal wear after about 4700 miles on the oil. Insolubles were low at 0.3%, showing good oil filtration. No anti-freeze was found, but we did find a minor amount of fuel. This level is below our problem range and my be normal if you do a lot of city driving or idling. Suggest running your next oil 4500 miles. Wear should still look good."
1999 BMW M3
3.2L I-6 (S52)
Royal Purple 15w40
Al 6
Cr 1
Fe 15
Cu 3
Pb 0
Sn 3
Mo 119
Ni 0
Mn 0
Ag 0
Ti 0
K 2
B 14
Si 6
Na 2
Ca 4135
Mg 14
P 926
Zn 1182
Ba 1
